The smallest freewheel made is 15t (AC Racing). I suggest you get a larger chainring. For me, I got around town just fine geared 38x16. And that's with hills (long and short).
Good luck
Curious
Good luck
Curious
32 x 13 works out to 64 gear inches. Still a little low, but better than what you are currently running. And it is easier changing out a cog rather than a ring.Chewieez said:Thanks...
So far I've found a Dicta 14t and an Odysee 13t bmx freewheels. I'm not sure if the threading would be the same yet.
http://www.bikemannetwork.com/Merchant2/merchant.mvc?
I have thought about getting a new chain ring. I am running a WI One crankset though and the rings aren't the cheapest around.![]()
Mojo, did you mean "toodling" (slow) or "tooling" (fast)?BikeMojo said:On my Soma fixie I run about 70 gear inches, and that is good for 'toodling' around town.
I meant toodling around with geared folks.******* said:Mojo, did you mean "toodling" (slow) or "tooling" (fast)?
I never knew that fixed riding made things so simple. Thanks for the article. No matter what they call it, I believe the power of fixed (and SS) riding lies in the riders head.******* said:Remember that a fixed drivetrain acts as a Holonomic Scleronomous Gyrator. (see Lee 2005) http://www.fixedgeargallery.com/articles/lee/lee.pdf
Chewieez, ******* brings up a good point. It depends on what speed riding you want for around town. Sticking with the 32t ring, you should try that 15t cog. Take it for a spin. See what you like.******* said:I tried 32/17 on my 29er today. That's 54.6 gear inches. I found it about right for around town.
Speed isn't a huge issue but I've ridden 32/18 on the road and it was tough. I definately felt like I was always spinning out and not going anywhere. Lots of coasting on the flats b/c I couldn't pedal fast enough to go faster.BikeMojo said:Chewieez, ******* brings up a good point. It depends on what speed riding you want for around town. Sticking with the 32t ring, you should try that 15t cog. Take it for a spin. See what you like.
BTW nice find on the 4one5, I tried to get one recently but they have been on back order since last year. Do you have the black (631) or the Silver (Tange) frame?
you still may end up with two chains. One longer for off-road gearing and one shorter for the road.... depending on what gearing you end up with. Not a big problem, change the chain when you change your cog...Chewieez said:Speed isn't a huge issue but I've ridden 32/18 on the road and it was tough. I definately felt like I was always spinning out and not going anywhere. Lots of coasting on the flats b/c I couldn't pedal fast enough to go faster.
I think I may try to pick up a 13 or 14t cog on the cheap and see how it works out. And yes I agree, changing out a freewheel seems easier than the chain ring on the WI cranks. And also I shouldn't have as much chain length differences.
Oh yea I remember that now. Nice, the 631 frame is killah.Chewieez said:I have the black 631 frame. I bought it used off of a local rider here in Nashville. It was definately the deal of the century for me. I'm really enjoying riding it.
