Probably got the answer right there...Sorry I should have mentioned I do have a front suspension but I have it locked out. I'm riding on a fairly smooth bike trail without much vibration. I'm riding a Cannondale Quick CX3
If I take my hands off and shake my arms out they feel better after about a minute or so. I'll try moving my hands around, I was thinking I might not have enough bend in my arms or something but I get a little bend now.
Good call. Be sure you're staying loose and not tensing up all the time. I have to remind myself to stay loose. That just makes you a better rider in general.don't white knuckle it? lol
+1 on this. I may be a MTB n00b, but I know the upper extremity pretty well.Probably got the answer right there...
Proper arm position is very relaxed...
Start with the wrists, set-up the brake levers so that if you put a finger or two on the brake lever the wrist is straight...this provides a quick and easy way to ensure you arms are in the right position.
Then let your shoulders relax and fall down, the elbows will not stick out....
Then imagine a helicopter attached to the very top of your head pulling you forward...extend your neck...
Bingo...
The trick is after every hard effort you need to remember to relax back to this position..
