Slow day at the office and I have been left in charge, so I thought, lets post on MTBR.
Some general questions to get feedback on purchases I want to make and other curiosities...
1) What do you wear with your full face... sunglasses or goggles? My Oakleys don't fit well at all when I wear my Remedy (the Oakley style with the straight arms that wrap around the head get caught up in the padding of the helmet), so I am looking for an alternative. If you wear sunglasses, what type fit for you? If you like goggles, any suggestions on type?
2) How much do you like to drop your saddle on descents? Right now I ride a 350mm post and when I descend I put it as low as it will go (5.6" drop due to interrupted seat tube). This leaves about 4 inches of post exposed (although I wouldn't mind if it went lower). Basically I like to get seat completely out of the way. Problem is that I could use a little longer seat post, but with the interrupted seat tube it would mean even higher saddle on the descents. Looked at gravity droppers, but 4" drop does not get the seat out of the way at all. I have even tried runs with the seat set as high as it would be with longer stem or with gravity dropper and it is not comfortable. I guess I am wondering if my low seat preference is just that "my preference" or is because I am still new and once I am a better rider I won't want as much drop?
3) What is your favorite line down the waterfall? What is the easiest line? Hardest line?
4) What is the most Jack in the Box tacos you have ever eaten in one sitting? I maxed out at 12 in college.
5) If a co-worker gave you a Scratcher Lottery Ticket for Xmas and it won a thousand dollars, would you share it with them or keep it all for yourself? If you would keep it, would you tell them you won?
6) When you swap your big ring for a bash guard do you re-adjust your front derailleur or do you just remember not to go into the highest gear? Not sure if there is a way to adjust the high limit on the front derailleur?
7) If you could have any thing in the world, bike related, free of charge, what would it be?
Happy Holidays. Cheers!
