1 - 16 of 16 Posts
· Vaginatarian
they're not UST
they are tubeless ready, which means you need sealant and possibly a rim strip
tubeless ready is basicly a regular tire with a ust type bead
500g is pretty light, the biggest problem Ive had with light tires is the sidewalls are not so tough
real UST tires are airtight, they have an extra rubber coating that adds weight and strength
· Vaginatarian
PimpinD said:
they can be, but they are not UST
do you have UST rims?
if you have UST rims then you can use any tire, a ust tire will be tubeless, wont need sealant and wont need a rim strip
you can also use tubeless, tubeless ready, TLR, 2Bliss, etc. they all require a sealant
and you can use regular tires with tubes
there are 3 types of tubeless
UST, has special bead and airtight layer of rubber
tubeless, etc. has bead but needs sealant and maybe rim strips
ghetto tubeless, regular tire & rim with sealant and rim strips
most people use sealant even in UST for puncture protection
UST is probably the most durable and heaviest
tubeless , etc. is the most effective as far as lower weight and better traction (due in part to the thinner casing) but the sidewalls are weaker
Ghetto is the cheapest and least safe method but alot of people have had great sucess
this is the ust model of the tire youre looking at
http://www.pricepoint.com/detail/11...ntain/Hutchinson-Python-UST-Tubeless-Tire.htm
· Vaginatarian
just found this on their website
MTB Tubeless Ready has been conceived for riders that want improved performance and weight from their tires. No more difficult tire mounting Tube type tire on a Tube Type rim plus a tubeless conversion kit. Tubeless Ready is the solution that offers maximum safety in an extremely light tire. How does it work? A tubeless type tire (casing and beads) seal is created by latex and not the rubber of the tire.
Tubeless Ready must be inflated with a Fast'air liquid+air cartridge as the tire is not inherently airtight. The tire may also be mounted with a regular tube if necessary.
Used in competition by Julien Absalon and Team Orbea, Tubeless Ready technology will satisfy the most demanding and hard-core riders looking for high-performance and weight savings.
Advantages :
Due to the lightness of tires with Tubeless Ready technology, the ride and responsiveness that the tires deliver is exceptional. On a Tubeless set-up, Tubeless Ready tires enhance the already outstanding characteristics of Tubeless tires. Comfort, performance and grip.
ATTENTION : ...
Weight :
Weight savings on Tubeless Ready tires are as follows with 30 grams of latex from a Fast'air cartridge in each tire.
- 5% Lighter than a Tubetype Light tire +an Air Light tube
- 20% Lighter than a Tubetype Standard + standard tube
- 10% Lighter than a Tubeless Light tire
- 25% Lighter than a Tubeless Standard tire
Sizes Available :
Available in 26x2.00 Piranha & Python tires ; 26x2.15 Toro ; 29x2.10 Python & 29x2.15 Toro tires.
The advantages of the HUTCHINSON TUBELESS LIGHT
TUBELESS LIGHT delivers the same advantages our TUBELESS LIGHT system does and then takes it up another level in order to
Reduce the weight : Its revolutionary technology makes each TUBELESS LIGHT tire the lightest tire in its category (up to 15% lighter).
Increase the output : The optimization of each component of TUBELESS LIGHT tires makes it possible to increase the output by the reduction of the rotaring weight.
Reduce wear : The specific mixture of carbon-reinforced rubber on the TUBELESS LIGHT adds a higher degree of resistance and increased tire life while preserving flexibility and comfort.
Improve the retention of air : TUBELESS LIGHT simply holds air better : four times higher than TUBELESS tires (5g/24h instead of 20g/24h)
· More Torque
Advantages :
ATTENTION : ...
Weight :
Sizes Available :
Great info...thank you.
1 - 16 of 16 Posts
