1 - 10 of 10 Posts
Enthusiast
Discussion Starter · #3 ·
Sorry! I hadn't fully unwrapped the frame.
Did check the eBay listing again, and the rear dropout is listed as 10x135mm thru-axle. There's a 12x142mm adapter available at extra cost. So the mystery is solved, and I just need to decide now which of the two options to run with. Either way I'm looking at a new wheel.
Land of the 230+
Even though the listing states they were 10x135, mistakes sometimes happen. Are they open dropouts? Meaning you can slide the skewers into the slots? Or is it a simple hole in each dropout, threaded or othewise? 135 will be a slot for sure, and while its hard to see in that pic, I don't think its a slot.
transmitter~receiver
It's not a q/r. The question is 135 thru axle or 142 thru axle. In either case it is not an open dropout.
OP - on a 135 the face of the dropout is flat, meaning that you have to have the wheel aligned right by holding it in place to get the axle through it. on a 142 there are recesses on both sides that the wheel slides into, holding it in the right place for you to put the axle in.
Land of the 230+
Thats fair, but the only 10x135 thru axles Ive seen are for use with QR dropouts, not a thicker threaded dropout or one with a recess for an E-type bolt. If it is a longer T/A that threads into the opposite dropout, I would think it would be proprietary to that frame then, and usually be provided with it.
EDIT: I guess I may be confusing a 135x10 "Thru Bolt" and not a true "Thru Axle". Apparently I am adding more harm than good to this thread.
Enthusiast
Discussion Starter · #8 ·
Jonathan is feeling Beyond Boneheaded (tm) now. Because here is what he saw when he pulled off the spacing tube between the dropouts:
Bicycle part Bicycle accessory Bicycles--Equipment and supplies Bicycle Bicycle frame
LOL. So obvious now that I actually look. Am feeling awfully silly for having begun this thread.
The good bit is that I won't need a new wheelset after all.
1 - 10 of 10 Posts
