1 - 15 of 15 Posts
· Registered
Hi all,
I don't know about you but while NW chainrings are mostly OK riding SS, non-NW rings just seem that touch quieter and shed mud better.
So....
Can you still buy non-NW, SRAM direct mount chainrings?
I can only really find the MRP bling rings and I think they have been discontinued so availability is tricky.
Other option I have run in the past is a 104bcd spider and then 104bcd ring but lets be honest- spiderless looks good :)
Any ideas then on non-NW SRAM direct mount chainrings?
Ta!
· Registered
I may be off-base, but I would think the bigger issue with noise is the taller tooth profile of 1x chainrings. I'd imagine you'd be hard-pressed to find a direct-mount ring with a traditional tooth-profile (for a single-speed or fixed-gear specific chainring).
· Registered
Discussion Starter · #3 ·
The height is a good point. A few years ago there were quite a few options but as you say a traditional tooth profile direct mount ring is a bit niche now.
I think ethirteen did some, maybe Blackspire too??? I am struggling to find them now
· Registered
The post above might be a joke... but I have done that before in order to use a half link. A lathe was helpful to keep the chainring spinning and ensure even material removal from each tooth, but it worked great!
· Registered
No joke! I've never tried it but it seems simple enough to shave off the wide teeth. Maybe even trim down the tops a little bit if it's too tall. 👍
· Wanna ride bikes?
I haven't been aware of any DM non-NW rings in years. I'd even be happy with a 104bcd option but can't think of any of those at the moment either. I'd LOVE to have a non-NW Shimano 96bcd option in 33t, but good luck finding that. Also could it be an oval? TIA ;)
Last time I needed something that didn't exist I reached out to a bunch of manufacturers to see who would make something for me, Garbaruk ended up doing a great job for me, gave me exactly what I wanted, did it in a reasonable timeframe, and it didn't cost an arm and a leg. I'd reach out to them if you decide to have something made.
(This was pre-covid, I've noticed in the past two years most companies are too busy and less interested in doing custom one-off projects, but you never know until you ask.)
· Registered
Can use a 1/8" chain and a half link, if desired.
I used a pintle chain on my last change. Noisy bugger, wouldn't recommend for regular riding. It did soak up getting dragged across a piece of concrete on the trail with aplomb, though.
· Registered
Discussion Starter · #12 ·
I haven't been aware of any DM non-NW rings in years. I'd even be happy with a 104bcd option but can't think of any of those at the moment either....
Last time I needed something that didn't exist I reached out to a bunch of manufacturers to see who would make something for me.....
Custom is my backup plan. There used to be a few making one off parts as well as the bigger companies so I will potentially give them a go.
Non-NW 104bcd rings off the top of my head readily available would be Blackspire Mono Veloce, Velosolo, Renthal SR4, Surly steel... but yes not a ton of options at all which is really frustrating. NW rings are mostly ok but a normal tooth profile ring for SS is just that little bit better IMO
· Registered
Did they ever make them? Is direct mounting compatible with a 2x system? If not, I would see no reason for them to even consider making a non-normal wide option.
1 - 15 of 15 Posts
