Are the new Vanilla R 130s adjustable down to 80mm of travel? Or just 100mm?
Thanks.
Colin
Thanks.
Colin
And use really heavy spring compared to the 130mm setting.MK_ said:I don't see why not. The manual says 100, but that's probably because the only spacer provided is the 30mm one. You would need to get a hold of a couple 20mm spacers and follow instructions from enduroforkseals.com concerning the 125mm Vanilla R and replace the 25mm spacer with 30mm one in the pictured configuraion.
_MK
