No brake adapters are not...
"standard" by any means. That doesn't mean that the shimano adapters won't work with the Formula brakes. But there is absolutely no guarntee that they will. Calipers from different manufacturers often have different shapes that can dictate a specific shape for the adapter. Also with shimano calipers there is often the "option" of having a direct IS or Post mount configuration. This doesn't even take into account pad positioing in the caliper, pad width etc.
Anyway, you can wait and see. Unless your XTs are completely toasted, you won't miss out on a weeks worth of riding. If things don't work out, you'll just have to ride with the XTs till the Formula adapters get there. If you want to have insurance or the XTs are toast I'd say get the Formula adapters on the way now. That'd be the safe bet. Because you never know what combination of calipers and adapters will work and what won't without trying. It's pretty obvious by the lack of responses that few if any others have tried the combination. So play it safe. :thumbsup:
Good Dirt
Good Dirt
