1 - 7 of 7 Posts
Hack Racer
I got a set of XTR M965 front and rear hubs super cheap from a friend. They only accept the shimano Center Lock Rotor Mount discs/rotors.
So my question is, will the shiamno SM-RT96 disc rotor work with my Avid BB7. Will the XTR hub position the rotor at the same position as the IS 6 bolt hubs?
Hack Racer
Discussion Starter · #4 ·
So basically the only way I can verify if this setup will work is to get a rotor, mount it and put the hub in the fork and see if it will fit?
I tried to find some dimensions/specs of each system to see if I can cross reference the two and determine if it will fit. No luck...
1 - 7 of 7 Posts
