Klonk explained
The klonk comes from play in the bearings. To get rid of the klonk disassemble the freewheel by removing the cap (two small holes - you can make a tool with a piece of steel and two small bolts). There should be one or more washers that adjust the bearing. If you don't have acces to washers you can cut some out of paper - it is quite stable. Find the right amount of washers and put the top cap back on.
It worked for me.
Disassembly is by far the best way to clean the freewheel by the way. And it is quite simple once you have a tool for two small holes in the top cap.
It worked for me.
