1 - 3 of 3 Posts
If anyone currently has this combo, any measurements you can provide would be greatly appreciated (overall diameter, widths at various distances from the axle, etc). I'm trying to figure out if I can stuff one of these in my custom fork. Thanks.
Fatback
Tire width at the widest point on the casing is about 104mm. This will vary from tire to tire a couple mm. The widest point has moved at to a radius of 350mm from 320mm on the old tire.
Diameter is 750mm, or 29.5", about .5" bigger than the standard Larry, so .25" radius.
Discussion Starter · #3 ·
Thank you
Comparing to the measurements I have of a Larry on the UMA II, it sounds like the BFL will be 5mm to 7mm bigger all the way around. I have at least 12mm of clearance all the way around between my tire and my fork now, so it will be a little tight but should fit.
1 - 3 of 3 Posts
