I had posted this in the Suspension forum, but figured I would try here as the Pike is a little different on the Stumpy.
Trying to go to 140mm and had my LBS get the longer air shaft. The shaft is 10mm longer, but the travel is now 155. Also can't get proper sag and it doesn't feel quit right.
Pix shows 155mm and not a lot of sag considering it is at 20 psi. I did a mostly XC ride, but only used about 60mm of travel. When the fork was 130, I had it set at 65 psi.
Any thoughts?
Any thoughts?
