1 - 5 of 5 Posts
· Registered
I'm looking for real word feedback from anyone who has used these adapters to run a 135mm QR hub on a newer Karate Monkey or Krampus with the "gnot boost" dropouts. Any issues? Any gotchas to be aware of? Thanks!
· Registered
Only issue is that they tend to fall off when you remove your wheel. If it's been a long time since the wheel has been removed, it's easy to forget they're even there. I had one fall off my wheel on the side of the road in the dark when changing a flat after a 16 hour day of riding into a brutal headwind in New Mexico.
· Registered
I have run the washers with a KM as a single speed with a QR 27.5+ using Surly older style tugnuts on drive side which I would highly recommend in this case. Sufficient clamping force from 135 QR skewers is too much to ask for IMO. Note the newer style snugnuts don’t work with 135/QR axles. Otherwise washers work better than I was expecting. Saved me money on a wheel set for sure.
1 - 5 of 5 Posts
