I’m running a 180 single crown onyx on mine. And have had no issues at all. I’ve ridden it from bike parks to pedal trails no issues.
How do you like the Oynx? I’m debating on a new fork for mine, since the Balance is so stiff, i can feel the flex in my current fork.I’m running a 180 single crown onyx on mine. And have had no issues at all. I’ve ridden it from bike parks to pedal trails no issues.
Small 2020 Balance. The nice thing I really love about Canfield is they list the AtoC.. I think it's 565mm. My fork is 570mm, so I'm not sure a 180mm would be better or not.Is that the "old" balance? Sorry I can't remember.
I had the last model year balance and I felt like it wanted to lift the front wheel when I went to a 170 fork so I'd imagine a 180 would be worse about that on climbs. I'm also on an xl so you may have a different experience on a different frame size.
Yep, I’m thinking the same now. Not higher, but lower is what I’m looking for. Thanks for your thoughts on itI built mine with a 180 Fox 38. If all I was doing was shuttles and park, it would have been rad. But it was too slack for climbing and all around trail riding. I shortened it to 170 and was much happier. But I think you know this...![]()
Just buy a lithium already.Anyone know if a 29" wheel will fit on the back of a balance?
The ultra short chainstays on the Balance would be awesome for a 29er, though I suspect there's interference.
How do you like it as far as stiffness is concerned? Are you running the same fork now?I built mine with a 180 Fox 38. If all I was doing was shuttles and park, it would have been rad. But it was too slack for climbing and all around trail riding. I shortened it to 170 and was much happier. But I think you know this...![]()
It's been tried, not unless you short shock it to 120mm.Anyone know if a 29" wheel will fit on the back of a balance?
Don’t encourage him. It’s like feeding a raccoon. He’ll actually try it.It's been tried, not unless you short shock it to 120mm.
Haha! BTW I've ridden a few Balance with 180 and it definitely lost the trail bike feel. Same reason I'm not going 180 on the Lithium. Even though the rear out does the front. Are you trying to get the front lower or the whole bike lower?Don’t encourage him. It’s like feeding a raccoon. He’ll actually try it.
Thanks, I think it was some frustration with my current fork I finally have fixed that came out here, but I agree. I ran the Tilt at 150mm and I didn't like that either.. I think the bikes feel fine at the lower travel, which is unusual for me. I usually want to overfork all the frames, but the Canfields don't feel that way at all.Haha! BTW I've ridden a few Balance with 180 and it definitely lost the trail bike feel. Same reason I'm not going 180 on the Lithium. Even though the rear out does the front. Are you trying to get the front lower or the whole bike lower?
Ok, so circling back. The reason I'm thinking of doing this is to run a 29er fork at 160mm, which is the same AtoC as a 27.5 fork with 180mm. Then short stroking the shock to 230x60, giving it 155mm of travel, so making it 160mm front/155mm rear.Haha! BTW I've ridden a few Balance with 180 and it definitely lost the trail bike feel. Same reason I'm not going 180 on the Lithium. Even though the rear out does the front. Are you trying to get the front lower or the whole bike lower?
I've ridden a mullet Balance and liked it. With the 29er frount it doesn't feel like it's going to wash out. Less weight is needed on the front so it feels more darty if that makes sense.Ok, so circling back. The reason I'm thinking of doing this is to run a 29er fork at 160mm, which is the same AtoC as a 27.5 fork with 180mm. Then short stroking the shock to 230x60, giving it 155mm of travel, so making it 160mm front/155mm rear.
Mainly because the fork I'm looking at is only offered in 29in, and not in 27.5. Does this sound crazy?
It does--but I'm still going to run 27.5 wheels front and rear--just a 29er fork since they won't be making it in a 27.5 :/I've ridden a mullet Balance and liked it. With the 29er frount it doesn't feel like it's going to wash out. Less weight is needed on the front so it feels more darty if that makes sense.
Ohlins RXF38 comes out in February. You can actually run them in coil, unless DVO, Fox 38, and the RS Zeb.Oh, ok. I think it's a try and see type thing. Maybe get a low stack bottom cup to help with it if you don't like it. If you like the fork a lot. Sometimes it's worth adjusting to it. What fork?
