Cavalerie Effigear Gearbox, high pivot, twist or trigger shifter, can shift up under power, but like the Pinion it can only shift down with the torque removed.
They have a new long travel 29er in carbon First Look: Cavalerie's Blackbird Carbon Gearbox Bike - Garda Trentino 2019 - Pinkbike, but I'm more interested in a short travel 29er like the Anatrail.
I just sent Cavalerie an email asking about getting a frame set in the US.
The gear range is a little bit smaller (444%) than a 12sp deraileur set up (510%), it sits between the two P9 Pinion gear boxes (568%, 364%), weight is similar to Pinion 12sp (2640gm vs 2600gm), and it looks like a good design in terms of how it's positioned in the frame.
I do wish it was available on other bikes, but so far I think Cavalerie is the sole user.
www.cavalerie-bikes.com
www.pinkbike.com
Cavalerie Bikes⎪Effigear
Découvrez la technologie des boîtes de vitesses Effigear, qui équipent tous les vtt Cavalerie.
Effigear Gearbox : How Does It Work? - Pinkbike
Every time we present our Effigear system, while at a show or simply when we are out riding, the question "How does it work?" surfaces quickly. Here's the answer.
