That's exactly what I was originally thinking when I put the Talas 36 RC2 on mine. Just didn't work out for me. When I pulled her off to sell I put it up next to my Talas 32, both dialed to 130mm. The Talas 36 was close to 2" taller for A-C distance! Which made MY BLT far too slack for my tastes. Test rode a Pike today and feels every bit as plush as the Talas 36 yet keeps a similar A-C as the 32 so that's definitely the route I'm going.GFWD said:Thanks for the replies. The reason I am asking about 6" forks isn't for the extra travel, but for the reduced head angle. I have recently moved, and the riding in my area is much steeper than what I have ridden before.
I am not in a position at the moment to buy a new, longer travel bike (nomad, reign, etc) so was hoping I could put a longer fork on the BLT to relax the ride a bit. I would probably look at a talas rc2 for the travel adjust, and run it in 5" mode most of the time, while saving the 6" mode for when I go riding with the 6" plus group of riders.
I guess I will have to do some more thinking.
Did you go with the air or the coil version?Climb-n-Bomb said:Just got a BLT and put on the Pike 454 instead of the REV 426--- it has been sweet.... my downhill skills are already better or it might just be that the Pike has helped hide my deficiencies--regardless is has been a blast to bomb like I never have before!!!
dave
A Foes FXR was designed with a 6" fork in mind as was a Nomad so of course they're going to feel fine on the twisty stuff. My point is IF you start messing with forks NOT designed for your frame then you'll run into A-C issues that WILL affect headtube angles and thus the handling your bike was designed for even if you adjust the travel up or down. A 2" A-C difference is a LOT to compensate for.phunk_dup said:I have a 36Van on the front of mine and love it, I like the slacker angles and dont find it a problem on tight twisty rooty stuff that we have down here in NZ. I had considered putting something adjustable on and have a pair of Z1 SLs to try, but probably wont bother as it rides too well to mess with.
Not sure if you were refering to me, but my positive comment was for the 36 on a BLT, the 36 normally is on my Moment but i may buy one especially for the BLT. I didn't feel as if the 36 made the angles too slack, and the bottom bracket height still felt ok. BTW my experience has been that the first gen brown 36 talas can make any bike feel like shite, whereas the Van has the opposite effect.Gman086 said:A Foes FXR was designed with a 6" fork in mind as was a Nomad so of course they're going to feel fine on the twisty stuff. My point is IF you start messing with forks NOT designed for your frame then you'll run into A-C issues that WILL affect headtube angles and thus the handling your bike was designed for even if you adjust the travel up or down. A 2" A-C difference is a LOT to compensate for.
Have FUN!
G MAN
PS - So far we have three positive comments for a 36 and NONE on a BLT. The 4X has an even lower BB height than the classic while the BLT is higher than the classic so I could see how that could work and the others are on a Foes FXR and an Ellsworth Moment BOTH designed for 6" forks. Anyone actually have a 36 (or other 6" fork) on a BLT (THAT IS A BLUR LT PEEPS, READ THE QUESTION) and like it?
I have a BLT with Fox 36 Van, that was my point :eh:Gman086 said:PS - So far we have three positive comments for a 36 and NONE on a BLT. The 4X has an even lower BB height than the classic while the BLT is higher than the classic so I could see how that could work and the others are on a Foes FXR and an Ellsworth Moment BOTH designed for 6" forks. Anyone actually have a 36 (or other 6" fork) on a BLT (THAT IS A BLUR LT PEEPS, READ THE QUESTION) and like it?
