pace rc31. about 700g uncut, in a 440mm length. disc only, unless you by the canti clamps.XCBob said:I was thinking of upgrading my stock Bianchi rigid fork to something a bit... "plusher" Possibly a Spicer Ti or maybe a Winwood Purist??? Anyone ridden a carbon fork? Anyone ridden both Ti and carbon??? -Bob
Thanks Shiggy. That takes the Purist out of the running. -Bobshiggy said:I saw the Purist at Sea Otter. Looks good except clearance is just 59 mm between the blades. Many 2.3" + and some 2.1-2.2 " tires will not fit.
Winwood also makes a carbon mtb fork, but for some reason is not susp-corrected.XCBob said:I was thinking of upgrading my stock Bianchi rigid fork to something a bit... "plusher" Possibly a Spicer Ti or maybe a Winwood Purist??? Anyone ridden a carbon fork? Anyone ridden both Ti and carbon??? -Bob
The Purist is the MTB fork.roadiegonebad said:Winwood also makes a carbon mtb fork, but for some reason is not susp-corrected.
Bob,XCBob said:Where can I find a Pace rc31? Are they available in the States?
Is the flex a problem with disc brakes? do you find any rotor rub during a climb?shwinboy said:I ride a pace. I love it. I came off a 80mm fox vanilla and while it's not as plush I actually prefer it for its directness, uber quick stering and the fact it's 1.3kg lighter. It has a noticable fore and aft flex while being remarkably rigid when you try to trist the wheel. IMO it rides much better than standard steel or al rigid forks. It also has heaps of room for big tires.
XCBOB,XCBob said:I was thinking of upgrading my stock Bianchi rigid fork to something a bit... "plusher" Possibly a Spicer Ti or maybe a Winwood Purist??? Anyone ridden a carbon fork? Anyone ridden both Ti and carbon??? -Bob
Current RC31's are 440mm a-cHoSS said:What was the shortest axle to crown length these forks came in? Where the older RC30's any shorter?
I mail ordered mine from bromley bike in the uk.XCBob said:Where can I find a Pace rc31? Are they available in the States?
No And I havn't noticed it twisting while braking either. It's better at resisting twisting forces than my fox.lomoid said:Is the flex a problem with disc brakes? do you find any rotor rub during a climb?
