1 - 14 of 14 Posts
· Registered
Discussion Starter · #3 ·
you are correct but I am having a custom bike built and I need the 4x104 to work, I already have the S-Works road cranks and just need to swap the spider over. the MTB cranks use an 84mm wide BB30 shell where as everyone else uses a 68 or 73mm BB shell.
· Registered
Discussion Starter · #5 ·
398g includes
Both 175mm arms
2 Ceramic Bearings
snap rings, spacers and wave washer
everything but the spider and chainrings
I will be running belt drive, the belt sprocket is very light
· Registered
scooter916 said:
398g includes
Both 175mm arms
2 Ceramic Bearings
you ABSOLUTLY HAVE to send me pics of this when you get it done!
i want to know more about this! you may be building the coolest bike ever,im totally serious.
· Registered
Discussion Starter · #8 ·
Thanks,
I'm having a custom SS made for me by Patrick Cycles.
just a teaser but specs will include
BB30 bb shell, ceramic bearings S-Works carbon cranks with Crank bros 4 ti pedals
S&S couplers on main frame for travel and one on seat stay to allow me to put on the belt
King headset
I9 wheels with Alligator rotors Stans Raven/Crow tires tubeless
custom ano Thomson masterpiece and x4 stem
Syntace Duraflite bars
KCNC levers Nokon housing with BB7's all hardware replaced with Ti
Gates belt drive
frame will have the BlackCat swinging dropouts as well
Fox F29 with travel reduced to 60mm
and to top it all off a *****in Spectrum powdercoat
its also a 69er SS full fillet brazed goodness
· Registered
Discussion Starter · #11 ·
I'm just hoping some one has a bike with the cranks and had upgraded to the 2x9 spider and doesn't need the triple spider anymore, I am having a hard time finding the 4x104 spider
· Registered
Hi i have the complete 2009 epic s-works with the standard 3x9 setup. I have wanted to change to 2x9 since i got it. If you can get a hold of the 2x9 spider i would be happy to swap, otherwise i will let you know if i get it myself, then you can have the 3x9 spider.
Please send me an email if you have interest.
Thomas
· Registered
I have the 3x9 now and am changing to 2x9. I have the 2x9 chainrings and spider, but need to get the chainring bolts. If I can get the bolts anytime soon and get these parts changed over I would consider offering the triple spider to you.
Why don't you just order the spider off the Specialized website? It looks like both the double and triple spiders are available now... @ $75 a pop....
· Registered
Discussion Starter · #14 ·
I got my spider but the cranks are too narrow to clear the stays, I ended up getting the first pair of ExtraLite BB30 cranks in the states. Saving the Spec cranks for a custom cross bike I will have built later this year
1 - 14 of 14 Posts
