You probably don't, unless the Romic has position sensitive damping that squeezes down at the end of the stroke, or you can get a dual rate spring for some end-of-stroke ramp-up.robertg said:I want to try a coil shock on my bike...
Nate - my AVA (nonpropedal) goes through it's travel pretty damned easily as well so I think it's the shock and not your particular model.Speedub.Nate said:Well, if BB is riding one, definitely PM him for his input. I haven't met him, but we ride some of the same trails and the guy clearly knows his bike.
I'm surprised everyone is liking their coils so much, but what I've all along assumed to be the fairly flat spring rate of my AVA could in fact have been a quirk of the ProPedal damping -- that may have to remain a mystery.
I was weighing approximately 210 pounds (+ gear) while riding this particular setup and was frustrated almost from the start. Changing back to my AD12 was a blessing.
I'm over here too....MMcG said:There is a guy over on Ridemonkey.com that was using a Romic on his 2004 Hollowpoint for a while - I think it performed okay for him. But I think he got a 7Point and thus went back to putting an air fork on his Hollowpoint to lighten it up a bit.
I think is username is -BB- over on Ridemonkey.com - you might want to send him a message to get his thoughts on a Romic on a Hollowpoint.
Hope this helps.
Mark
Where do you live?Speedub.Nate said:Well, if BB is riding one, definitely PM him for his input. I haven't met him, but we ride some of the same trails and the guy clearly knows his bike.
-bb- said:Where do you live?
Don't bother PMing me on RM though.
My work blocked that site, and I am pretty much a work-only surfer.
After work and on weekends, I'm usually riding, or having a beer.
Again, as for my thoughts on the Romic on the HP, I think it worked fine.
You need a slightly heavier spring (than the bike it came off of) b/c of a higher leverage ratio. I think I had a 700lb adn I weigh about 185. It worked fine though, and that with a Vanilla 125 made the bike MUCH more trail worthy. Oh, and a 70mm stem.
It still climbs great, and you can bomb all but the toughest DH sections.
Now with my 7Point7, I can climb ok AND bomb the toughest DH sections.
I just can't climb as well/fast.
Out here in SoCal, the trails either go straight UP or straight DOWN. That is why I use the 7Point more.
If I were on the east coast, I'd probably ride the HP a bit more.
It is better on tight singletrack, and is faster on flatter trails, although with the setup I had, it could still take some serious abuse.
I think that the key was putting on the 125 fork though, just to get a slacker HT.
robertg said:Thanks a lot BB. I have recently put on a Vanilla 125R, but haven't ridden the bike yet with it on (just around my parking lot). I am glad to hear that you had a good experience with the Romic. Now I just need to find one at a reasonable price. Thanks.
