It seems the rear pivot bolt that is supplied w/ the bottlerocket and the spacers that come w/ the ROCO TST-R (or any ROCO I'd imagine) are not sized appropriately?
I have a tiny bit of slop between the spacer and the pivot bolt. Is this an issue with anyone else?
I've cranked down on the bolt with excessive torque which does not seem to do much other than overclamp the spacers (play between the bolt and spacer still exist). I also took the shock and spacer into the local Transition shop and they say that's "normal". He even showed me a new frame right off the wall w/ the same shock has the same play in the spacer when disassembled.
I'm just wondering if anyone has found aftermarket spacers or a fix for this...
