I whacked my nearly new rear wheel into a curb my last ride out. I was running about 25 psi in the rear tire, but the curb edge blew right through that and severely bent the lip of my XR4.1d rim, knocked the wheel a little out of true (wow, strong build), and now apparently has mucked up the hub as well.
Symptoms: rotating the non-drive-side spacer is hard. It doesn't feel like metal-metal contact, it just takes excessive effort to spin, feels like rotating the axle through molasses.
Cause: Hope says maybe the axle is bent. I need to remove it and check alignment on a table.
Anyone else do this to a Hope hub? It frustrates me that I rode my hardtail for years and years without a problem. Then I drop tons 'o cash on the latest and greatest, and it fails almost immediately.
How hard is the hub to disassemble? According to Hope, I just pry off the non-drive-side spacer with some pliers and tap the axle out with a (plastic) hammer from the drive side. Umm....did they leave out any details?
