1977 grams = 4.35853892 pounds according to speedgoat.compm55 said:I'm seriously considering this fork for my 06 Enduro vs. the Fox 36. But I was wondering if anyone has any comments about it's performance? Has anybody weighed one?
Well, that's only partly correct. The weight 1977 grams is without the steer tube. And as you all know it's pretty hard to ride without it. So you have to add aproximately 250-300 grams to get the final weight.jp3d said:1977 grams = 4.35853892 pounds according to speedgoat.com
I have a 2004 Z1sl and it is about that weight also. I might get either one of these or maybe even a 66sl (about .8lbs heavier). There is a massive thread about the 66sl here: http://forums.mtbr.com/showthread.php?t=148489
Anders E said:Well, that's only partly correct. The weight 1977 grams is without the steer tube. And as you all know it's pretty hard to ride without it. So you have to add aproximately 250-300 grams to get the final weight.
Now, with that said, the weight of the Marzocchi Z1 FR SL will most likely land in at about 2250 gr. (with uncut steer tube.) The weight of the Fox 36 RC2 is 2400 gr. (with uncut steer tube and w/ 20 mm axle.)
And, if you haven't allready seen it, here's a list which tells you how much each Marzocchi fork weigh.(offcourse, still without steer tube)
The link.
Anyway, good luck with you choice pm55. They're both great forks so you can't go wrong with either of them.
correctjp3d said:I think Marzocchi actually is including steer tube now, they state the target weight of the 66RCX2 for example as "2950 g. w/ steer tube (255 g.)" so is that 2950g including steer tube which is 255g or 2950g without the steer tube which is 255g? Confusing. Someone else said in another thread about the 66sl that the weight is in fact including the steer tube.
no no, 5.7lbs for the 66sl. The 66light ETA (the heaviest one of the bunch) weighs in at about 6.5lbs. I'll be weighing mine thurs-friday.SpawningGround said:correct
Marzocchi now weighs them complete.
I've seen the 66sl weighed at 6.7 lbs. +- a little.
Mine just arrived today and the digital scale will arrive tomorrow. I will weight it before installation and post the weight.pm55 said:I'm seriously considering this fork for my 06 Enduro vs. the Fox 36. But I was wondering if anyone has any comments about it's performance? Has anybody weighed one?
I'm thinking about picking one up used. How do you like it? What's it on? Mine would go on a Haro Escape.jp3d said:I have a 2004 Z1sl
