jack.s said:
An inch or two.
According to my local bike shop, there isn't a way to do this.
Oh there's a way to get an inch or two.:thumbsup:
Salsa makes a 130 degree rise Moto Ace S.U.L. stem in lengths of 80, 90, 105, 120, 135mm lengths. Depending on the length of stem, that kind of rise will easily give you an extra inch or two.
I've got two of the Moto Ace stems for my Tandems which got 'em up to fit my riding position.
Another option is a DH riser bar which typically can be found with a larger rise (32mm+) than found in a XC riser bar (10 - 20mm). That will give you an inch and a quarter over a flat bar with no rise.
Another option, which is kind of neat, is the
Syntace System. It's a bar/stem/clamps combination that will let you dial in a variety of positions. This is probably the most expensive option, but will give you what you need.
Your local bike shop is probably busy doing what they do in the shop. An internet junkie who has been through the process of trying to get my bars up due to the short head tubes on 29"ers and tandems is easier qualified to point you in the right direction.
The final and most expensive option is to get a new fork and cut your steerer tube longer, use more spacers and dial in your fit. You could then sell the fork you took off the Paragon, but my guess is this option would cost the most of the four. Look through the picture thread on the 29"er board and see all the bikes with oodles of spacers, riser bars, long steerer tubes, high rise stems and what not to address this.
I saw a Sugar 293 like I ride this past Sunday at a WORS race and commented to the guy that he did a good job of not cutting too much off of his steerer tube when he installed his new fork. He had about 4 inches of spacers on the notoriously short Fisher head tube to get the bars up on an XL frame to fit his height. I cut mine a bit too short back in the day when I "thought" the head tube on my XL frame was correct. So I have had to counter that improper cut and short head tube with spacers, bars and stem to dial in the fit.
Not to worry, you're not the only 29"er rider who needs help getting it up. :-0
BB
