Try this...
Install the valve stem (either tubeless or from an old tube, it doesn't matter) but DO NOT TIGHTEN the nut down - just thread it on enough that the valve can't completely fall out. Now install the tire and goop (put both sides of the bead onto the rim) and once that's done, push the valve as far up into the tire as you can (without losing it in there) and then pull it back down and tighten down the nut for the valve stem. This should allow the tire bead to seat correctly near the valve.
Good luck!
-Walt
Good luck!
-Walt
