I wouldn't call it a budget tire but its a light tire. I ran forekaster up front and rekon in the rear as the Rekon is not a good front tire.I'm looking for a good budget tire here in Arizona and was thinking the 60tpi might fit the bill. Thoughts?
There is no possible thread count that will compensate for the Rekon tread design in "marbles over hard" as a front tire.Thanks again for the comments.
@waltaz, does the front wash out for you? Do you use the 120 or 60tpi? Right now I have Vee Crown Gems f/r (27.5x3.0, stock durocs/fex8), @16-17psi, I find that the front is washing out on the Vees and i want better cornering from the front, especially with the marbles over hard that we have here in Tucson
This is probably true.... in those conditions you're safer on something with more traction. I can't promise it's performance in Arizona but I had great results with an XR4 in 29/2.6, until I punched a hole in the tread. Faster rolling (I assume) than a dhf.There is no possible thread count that will compensate for the Rekon tread design in "marbles over hard" as a front tire.
I know people who like and use the Rekon in the front. But this is not the sort of trail condition they're using it on. It works in the front on hardpack. It doesn't bite enough for any loose-over-hard except for maybe a thin layer of sand or dust over hard. Fine gravel will be iffy and marbles over hard will be too much.especially with the marbles over hard that we have here in Tucson
I have lots of time on Rekon 27.5x2.8 and they're fine....I think they're worse in other sizes/formats.Also to further clarify, I'm switching to 29er wheels due to a rim breaking (my own fault) and being tired of pedal strikes.
120 TPI, and while I didn't have serious problems with it, it was prone to being loose in front. Depending on the bike and application, the best 2.6 tire I've found is the XR2 2.6 Team. Not overly burly-looking, but light, fast rolling and suprisingly durable. Hooks up very well until the tread wears down, then all of a sudden, it doesn't.Thanks again for the comments.
XR2 = Chupa. XR4 is knobbier and grippier.. it's good up front, I ran it with an XR2 rear.@Blatant, agreed and I've paid attention to that.
@Waltaz, thanks for the response. Is it the XR2s or XR4s that are basically renamed Chupas? The Chupas on my stock 27.5 rims mirrors your experience with the XR2. I guess I'm looking for something different....
My priorities would be cornering, climbing ability then speed.
