Ventana adopting Dave Weagle's "Split Pivot" design in its future bikies?
I doubt the split pivot design will do much to change the characteristics of the suspension feel or behavior. The design is still a single pivot, with a fixed length swingarm, it's the arc and the placement of the main pivot that determine how the suspension reacts to bumps. What the split pivot does do is free up the suspension from braking forces.Flyer said:If Sherwood could utilize this to better absorb square-edged hits
Agreed. The inherent brake squat on my TMoto provides very controlled descents through steps & ledges. OTOH, a more active rear brake would be a welcomed upgrade for this skidiot.Ciclistagonzo said:However, Sherwood's pivot placements cause the rear to squat a bit, and I'm not sure if I want to elimanate that.
I don't skid on my Bruja much at all, but then again, What I ride and what YOU ride are DRASTICALLY different so I'm not surprised if you are pushing the limits of traction and suspension design more than I do! :thumbsup:The Squeaky Wheel said:. OTOH, a more active rear brake would be a welcomed upgrade for this skidiot.
Aaron - You're doing a great job at bike designerCiclistagonzo said:I'm not quite sure what you are asking in the first question. Do you mean will the Split pivot lend to moving the main pivot (behind the BB)? I don't believe so since the main pivot is the dictating factor in suspension dynamics on any Single Pivot design. Even DW says so in his posts about the Split pivot. Sherwood has already found the best location for the main pivot for his style of frames.
On the brake jack Q. Stinkbugs are an insect that lifts it's bottom up high and lowers it's head. The FSR bikes and some SP bikes do this when you apply the brakes, the rear suspensions wants to EXTEND. Ventana's do the opposite they want to squat a tiny bit. This helps counter the natural weight shift forward and helps balance the suspension. The down side is, the rear suspension does not track the ground as smoothly as an FSR or probably a Split Pivot bike will. But this is ONLY when you are applying the brakes. The rest of the time the frame stiffness make it a superior design as the bike tracks straight and true.
Did that help any?
-Aaron
(Not a bike designer, but I play one on the Internet)
I'm basically asking if using a split pivot will allow moving the main pivot to improve the ride. Where exactly the pivot would be placed is a bit beyond my understanding of suspension dynamics, but I have noticed under heavy braking that my Ventana "skips" a bit. I realize that the main pivot is the dictating factor in suspension dynamics, but I also realize that pivot placement represents a compromise. You say Sherwood has found the best place for the pivot "for his style of frame." What I am asking is if using the split pivot would allow less of a compromise and allow Sherwood to design a frame, or "style of frame" that could be an even better all around performer?Ciclistagonzo said:I'm not quite sure what you are asking in the first question. Do you mean will the Split pivot lend to moving the main pivot (behind the BB)? I don't believe so since the main pivot is the dictating factor in suspension dynamics on any Single Pivot design. Even DW says so in his posts about the Split pivot. Sherwood has already found the best location for the main pivot for his style of frames.
Vertically or laterally? It seems to me that the more the wheel remains in constant contact with the terrain as a result of suspension action, i.e. vertical activity, the more "straight and true" a bike will ride. Perhaps I am misunderstanding?The down side is, the rear suspension does not track the ground as smoothly as an FSR or probably a Split Pivot bike will. But this is ONLY when you are applying the brakes. The rest of the time the frame stiffness make it a superior design as the bike tracks straight and true.
Wow, lots of questions there!SVSocrates said:I have noticed under heavy braking that my Ventana "skips" a bit....What I am asking is if using the split pivot would allow less of a compromise...
Thanks Vince, coming from you, that means a lot.mtnbiker4life said:Aaron - You're doing a great job at bike designer.
You're quite welcome, and frankly, thank you. It's been a few years, since before the previous board format change, that I wrote a disrotation on suspension dynamics. It was fun to dive back into it again.SVSocrates said:Thanks my man. Great, clear answers. I'd be interested to see the SP implemented just to get a "feel" for it. It might suit my ridng style better, or, it might not.
Thoughts? Lot's! About the DW link?SVSocrates said:Aaron,
Remember this discussion?
Anyhoo, what I was trying to ask you at the time is stated succinctly in this post:
http://forums.mtbr.com/showthread.php?p=3181362#poststop
Note _dw's response to it.
Thoughts?
Thanks,
Michael
My unsolicited 2 cents....Ciclistagonzo said:Thoughts? Lot's! About the DW link?![]()
OH! (kidding)
Not much different than before. The Main Pivot won't move, it was already at the best location for what Sherwood wanted in his suspension characteristics. Only the Braking physics would change.
-A
