Do you have a link? IF so, I know what my next upgrades are...Dan Gerous said:Doesn't Thomson came out with a tapered steerer replacement for the Lefty that allows you to run a Thomson stem... or any standard sized stem?
damion said:Do you have a link? IF so, I know what my next upgrades are...
scroll down a little bit for the printed photos and caption...Thomson had some genuine under the counter stuff that you had to ask nicely to see, which included a 1point5 stem and a steerer that replaces that on the Lefty fork and allows you to run regular 1 1/8thin stems.
Aren't the bonded Leftys bolted to the steerer and the bond is rather between the clamps and the Lefty itself? Kinda like the Carbon Leftys? Or are they bonded to the steerer too?damion said:My Lefty Max is a bolt on model. That new steer will not work with the bonded Lefty models.
I am not sure. It may be that you are right. I have not had a close look at one. Have you?Dan Gerous said:Aren't the bonded Leftys bolted to the steerer and the bond is rather between the clamps and the Lefty itself? Kinda like the Carbon Leftys? Or are they bonded to the steerer too?
Syncros was making one headshock stem.ToastR said:Are there some specific aftermarket stems that some of you have had good luck with or would I be better off finding something on ebay off a lefty?
