1 - 3 of 3 Posts
i'm haveing trouble installing the marzocchi rocco to my ironhorse sunday 05 top bracket with rebound nobe not fitting in properly anyone know what to do ????? i heard it has been done already....please help...../
New project, TBA shortly
rotate rebound eyelet 180 degrees. just undo the top bolt, rotate shock forward, put a screwdriver in the eyelet and twist. rebound knob should be facing forward.
You may need to sand a little of the top of the eyelet as well since it is a very tight fit. Also if you are still using the old bottom link make sure to remove the compression knob as it will contact the linkage if left in place.
1 - 3 of 3 Posts
