1 - 12 of 12 Posts
Hi,
I'm about to do a bike build and lean towards TALAS because I don't weight 150 pounds and have liked the instant height change with ETA on a Bomber.
Has anybody here tried this yet? So far I've only found the spacers for Hope Pro II with adapters from an eBay store as far as hub options.
I do ride rocky and rough stuff, but I don't huck and again, don't weigh much so I wonder if this new standard is throwing money away when compared to my wheel options with the old school QR standard.
Thanks for any input.
I'm UTarded
I've got an 09 Fox Vanilla 32 RLC with the 15QR axle in my hands right now, but I'm having a helluva time getting a hub. The hub that Shimano sent me is a centerlock hub. I tried to make it work with an Alligator adapter thing that I bought from PricePoint, but it doesn't.
So, I'm scrambling to find a 15QR hub with a standard 6-bolt pattern, but I'm not having much luck thus far. Hopefully I can either get a 180mm centerlock rotor or (better) get a hub with a standard 6-bolt pattern.
Discussion Starter · #3 ·
Thank you for your resoponse.
Between lack of shipping product and weight I went with conventional setup but did get White hubs with larger front axle designed for open dropouts.
I have no doubt this standard will sell to some or a large extent but open dropouts also gives me compatibility with my other bikes.
I am not sure a lot of people know the White hubs have the large axle and they're wonderful hubs. I could be wrong, but I also have a lot of confidence in going the route of proven products and custom (hand) built wheels.
Thanks again.
I'm UTarded
Yeah, it will be an uphill battle for the 15mm standard to catch on. I think it's a GREAT idea, but it will face lots of questions from consumers and manufacturers. As you and I have seen, compatible products are arriving very slowly.
I really, hope it catches on.
I think the 20mm axle idea is even better. And there is products available for it. But it is good to re-invent the wheel sometimes :D
I'm UTarded
Yeah, I've ridden 20mm thru axles pretty much exclusively over the past 6 years. I think it's a great solution for all bikes. But, then you get the weight-shaving XC crowd that think an extra 50 grams will be detrimental to their lap times who couldn't ever accept using a 20mm thru axle. So, therein lies the sweet spot for the 15QR.
Buy a Hope Pro II. They make the 15mm adapter as well as a 20mm adapter for their hub.
When I first heard of the 15mm qr I was thrown off to because it seems kind of ridiculous to reintroduce yet another standard to mountain biking. I'd to actually ride a bike with it and see how it compares to a 20mm axel. I have the same question as william 42 though, is a 15mm fork really that much lighter than the same fork with a 20mm axel? I ride a Lyrik, and I LOVE my maxel, it is such a great system. It is just as fast as any regular qr axel.
Don't think of 15mm as a competitor to 20mm hubs, but as a replacement for QR's.
powderboy said:
Good point... that's actually the right way to think about it. Fox/Shimano's intent wasn't to unseat the 20mm standard, but to convince folks that the old 9mm QR's should be abolished... a notion that I agree with whole-heartedly.
I guess that is a good way to look at it, it puts it more into perspective. And I definately agree with the abolishment of the 9mm qr, they quite frankly scare me. I am still curious about what type of weight savings are had over a 20mm fork, and the weight in comparison to a regular 9 mm Qr axel.
1 - 12 of 12 Posts
