they rock! the best if you want to convert any frame to a true ss bike. Think of me as your friendly neighborhood ENO-man.scarface said:thinking about tossing one in my VooDoo Ti, right now its a 1 x 9 and that is still too many gears![]()
I got one, and it's cool. also went from 1x8. keep in mind that you will have to use V brakes in the back, and I had to farg around with it a little to get the chain tension/brakes set up OK. but since then it's fine.scarface said:thinking about tossing one in my VooDoo Ti, right now its a 1 x 9 and that is still too many gears![]()
The disc hubs are available and work just as well. My bud has one on his Gunnar Rockhouse with a set of Avid disc brakes and it works fine. WI has some ecentric brake mounts coming soon, but an Avid has so much flexibility with different bolts and spacers, it should work on just about any bike.jh_on_the_cape said:I got one, and it's cool. also went from 1x8. keep in mind that you will have to use V brakes in the back, and I had to farg around with it a little to get the chain tension/brakes set up OK. but since then it's fine.
it'll be cool on a voodoo ti bike!
is there a way to mount a disc holder on the fixed side of the eccentric hub?Manicmtbr said:The disc hubs are available and work just as well. My bud has one on his Gunnar Rockhouse with a set of Avid disc brakes and it works fine. WI has some ecentric brake mounts coming soon, but an Avid has so much flexibility with different bolts and spacers, it should work on just about any bike.
