I've read a number of times that a limitation for longer travel dropper posts, is the seat post diameter itself. Something about the size of the bushings, overlap, something (I remember reading an article about it sometime, but can't find it offhand). I hear thats one of the reasons for the 34.9mm seat post diameter becoming a "thing".
I'm going to buying a new frame sometime here in the next couple of months. I'm noticing a few of the frames I'm considering have 34.9mm seat posts. But I'm curious if I'm buying new for the build if I "should" be going with a 34.9mm post for those frames, or if it would be a smarter move to grab a 31.6mm and shim it down, giving me something that I could swap around more in the future?
The one thing I can say after looking at the specs of the PNW Rainer 3, and Oneup V2, is that the 34.9mm diameter posts are heavier than the smaller diameters.
Here are the OneUp specs:
(31.6) 120mm 450g / 150mm 500g / 180mm 545g / 210mm 590g
(34.9) 120mm 545g / 150mm 605g / 180mm 660g / 210mm 710g
Here are the PNW specs:
(31.6) 125mm 474g / 150mm 524g / 170mm 554g / 200mm 598g
(34.9) 125mm 576g / 150mm 638g / 170mm 674g / 200mm 734g
Does anyone know if larger 34.9mm diameter dropper posts are actually more reliable than the their smaller diameter counterparts? Are they using all that extra diameter "correctly", and have less play or something? Just curious if anyone has any experience one way or the other.
I'm no weight weenie (my bike is ~37lbs right now), but if there isn't a difference in reliability or something between the two sizes, going with the smaller 31.6mm post, and saving some weight, and gaining some cross compatibility seems like it might be the better option? But if they are much better in some way, then I might be worth it.
Thoughts?
Thoughts?
