1 - 20 of 24 Posts
circumfrence measurement
With a 155# rider and the 2.25 & 2.3 Jones XRs at 40psi I measured 2280mm. I also noticed that my newer cateye has no instructions for a do it yourself measurement, but it will take the number.
I put a dot of grease on the tire and rode it across the garage, then measured. Works well.
Birthday Collector
I agree with ssmike - the Garmin are nice, you can have a few mounts and switch them between your rides in seconds. Clean and lots of information if you are a techno-geek like so many of us...
Super Moderator
Did you go as far as airing up to riding pressure and sitting on the bike when you did this?
Now with 20% more fat!!
jbogner - does your cateye hookup to your personal computer to take the data out, or do you manually enter the info from your cateye into the personal computer for training info etc? If the cateye doesn't, do other cycling computers connect to PC/Macs via USB or anything?
For me, I really love the GPS and all the software that is out there to take the data and crunch the numbers and help me learn from that info. I could see how a smaller and cheaper unit might be helpful, but if it requires manual data entry, then forget it!
Did you make sure to take chain and cog wear into your gear inch equation...
Most cycling computers allow manual wheel size input. if you are worried about exact tire displacement on uneven rocky terrain...get a hobby.
Cateye Enduro Is my pick. stores 2 separate wheel diameters' for those whom use multiple tire sizes. and very easy to add/change input.
There are lots of cycle computers out there now that have computer interface capabilities AFAIK, but for sure the Polar HRM do this and give so much data - I love my S725.
1 - 20 of 24 Posts
