Pinchflat King
I was excited by the whole tubeless option when it came to market because I would generally flat once a ride, if not more. It didn't seem to be a pressure issue and the only semi fix that I had found was running downhill casing tires, which really slow a bike down on the climbs. I bought a Stan's kit at my first opportunity and tried a number of conversions.
I eventually discovered that for this 225 pounder (before gear) the only tires that would stay on a tubeless converted wheel were actual UST tires or the aforementioned DH tires. Every normal tire that I have tried to run converted to tubeless has peeled off the rim or burped aggressively at some time, often in an inopportune fashion. It didn't matter if it went on tight, had a steel bead, seated well or anything. If a tire was not made to run tubeless it didn't work for me unless it was a 1200 gram monster tire.
On the other hand I have had great success with regular UST tires from Hutchinson, Michelin, Maxxis and Schwalbe.
I have used Mavic UST rims, Stan's rim strips, Bontrager rim strips - in a Bonty wheelset, and a ghetto tubeless using a 20" tube. The Bontrager rim strip has provided the most secure engagment, at least if you look at how difficult tire removal is when you try to change tires, but the wheels are a little light for us big guys. I run Mavic 819s on my trail wheelset and I am quite happy with that option with the appropriate UST tires. On my 'freeride' wheels I run heavier tires and I am currently set up ghetto which has not given me any trouble yet.
In all I have to say that when it is working tubeless is great, but for me there were a lot of headaches involved in determining what tires and wheels were compatible with me and my riding style.
