1 - 10 of 10 Posts
Hi
Happy Christmas and have a great New Year to everyone to start with!
I'm thinking about fitting a Fox RP3 to my next Preston, and wondered if it was upn to hauling around 240lbs around? I usually run either a Romic D Coil or Manitou Swinger 4 way air on my bikes, so any help you could possibly give would be very much appreciated.
Many thanks.
Air pressure
Just remember to regularly check the air pressure. That's the one drawback to this shock for a heavy rider.
Discussion Starter · #5 ·
Yeah thank you, I used to have an RC air shock on my Tracer, this was exactly the same, in fact I often check my pressures when running air shocks :)
Discussion Starter · #7 ·
starsky said:
Sorry, didn't mean that last post to sound patronising! I mean the RP3 seems to lose air quite rapidly.
Oh no not at all, I really didn't see it as patronising, so sorry if my reply sounded as if I did! :)
Thank you for your help, and Happy New Year! :D
Been using an RP3
Since they came out on my Ellsworth Id. My favorite air shock, and I have owned most of them. Smooth and supple as a Romic (my favorite coil shock) but keeps rear wheel planted better. Dont know if I would own it if I had to go much over the 2.6 to 1 leverage ratio, as extreme pressures are the death knell for air shocks IMHO. Jim
260+ here and ride a RP3 that has been PUSHed on my El Cap. The PUSH is not necessary, just my preference.
As long as the leverage ratio is in the 2-2.5x range most of today's larger volume air shocks should work fine for clydes.
I've got buddies north of 275 that ride Floats and RP3s all day long.
1 - 10 of 10 Posts
