1 - 9 of 9 Posts
ZEN RIDER!
i was also interested to see if any changes would be occuring seeing its been couple of years of the same frame. i know i know if it ain't broke don't fix it.
My only concern would be the frame was designed around a 5" fork & now the new trail forks are 5.5"
Any plans on tweaking the geo to accomodate the newer forks?
I would like to see Dw's split pivot as an option or standard feature.
Its only a matter of time before the fence wire is replaced with a solid 12mm thru, qr or bolt on.
Well as must as I wonder which company will first use DW Split Pivot, I just don't see why Ibis should offer the Mojo a split pivot option, even DW himself tells that SplitPivot is not to replace DW-Link and DW-Link is still superior then Split Pivot.
1 - 9 of 9 Posts
