Release 5c
Unboxing:
The box was in very good shape. Inside it was packaged very well, not any excess. The bike was in great condition, there was only some tire rub on the head tube. It came with the product manuals for all the major parts, shock pump, pedals, derailleur hanger, tubeless valves, mudguard, torque wrench, and some other small things I’m probably over looking. Everything you need if you just want to put it together and go.
Assembly:
I took the long way to the trail and checked everything. Greased and torqued all level link pivots. I only found one bolt washer completely dry and a little stuck, everything was torqued pretty much to spec. Checked rear derailleur hanger alignment, that was spot on. Removed spoke guard, reflectors, etc because.. umm weight. Retorqued cassette. Checked indexing on rear derailleur, only minor adjustment between the 5-7th cog. Setup tubeless, and both rims came pretaped! The rim tire interface was awesome and seated first try on each with a regular pump. Aligned front and rear brake calipers. Installed new grips, the OneUp EDC in the steerer tube, one decal, and my DMR Vaults.
Thoughts after assembly: I have a longer inseam for my height, and I could easily fit a 150mm with room to spare instead of the 125mm it came with. If I did it the quick way, it would have taken no time: the dropper post was installed in less than a minute; handlebars were setup well; and cable routing on the bike is solid. There is NO room inside the frame for a water bottle on a size medium. The smaller details are nice: they aligned the tire logo on the rim, the seat is angled correctly, they labeled left and right on the cranks for those who may be new to bike maintenance, crank boots on the crank arms, QR code to register, and easy to understand videos online.
First ride:
So I spent the night and morning getting ready to give myself a good few hours at my favorite trail center. Just to realize one mile out I forgot my brain bucket. So a 1 hour delay to pick up a new one brought me back and I only had one run. Anyways, the bike is phenomenal. I’m not going to talk as if I’m some Enduro Pro Bro, I’m a hobbyist who enjoys going fast and being outside.
The suspension is great and supportive. I thought I had the rear a little soft when I was prepping last night. Then during the ride I felt no bob unless I was standing to the point where halfway through I had to check to make sure I had the shock in full open, which it was. It’s super stable down and had to stop a few times to give the people ahead of me space so I wouldn’t run them down (I have a big huge total of 0 KOMs). I hit crank once and the bash guard once, when I normally have half a dozen pedal strikes a ride.
Component check:
I was initially worried about the 34t chainring even though it’s eagle. I was running the xt 11-46 on my old bike. Shifts were super clean and I had all the range I needed considering I haven’t ridden in a couple months.
The WT tires were great and I probably need to go down in pressure. I was running 24f-26r and the trail was super dry.
The novatec hubs are their new endurbro hubs. It’s over 80 poe by my count. They are crisp and can be heard but aren’t I9 loud.
The handlebar and stem work. Not much to say there besides the stem length seems on point.
Overall:
This bike is a great package. The only thing I can poke at is the dropper length, and I’m the kind that burns to change/upgrade all the time. It is perfect for the terrain I ride, where 160/170mm of rear travel is overkill.
I was originally looking at a Mach 5.5, Calling, and 5010. Once I saw this pop up I bought it immediately. The week of waiting made me wonder if I should have gotten one of the 5010’s on sale, or try and piece and part one of the other two. After today I have no doubt I made the right choice and spent my money right (not a dentist so this bike was a big deal).
Let me know if you have specific questions and I’ll the best I can.
