Pictured is a Pike Dual Air set @ 5" and a 7.5 x 1.75 RP23. I now have a Pike coil and Marzocchi Roco TST. I posted some pic's on MTBR , might turn up with a search , maybe 7-10mm all around a 2.3 Neo-moto.Spongebob said:nice Keen. Which fork you have up front? And on the rear, is that a 2.1 or 2.3? You have a picture of the rear clearances?
SB
My agressive riding was tapering a bit so I considered less travel maybe in a 29er platform, I am 6'4" 210lb. Rode a 29er but It was slower and less agile than the 26er. I wanted my RFX to have bigger wheels and less travel. 650b's were a good wheel size compromise. The RFX took well to the shorter rear shock / fork combo. Geometry wise HA is 68* , BB height is 13.5" - perfect for trail riding.pjlama said:Wow, very cool. How do you like it?
XL. I talked to somone @ Turner and thought they said a 650b wouldn't fit a DW .pjlama said:Seems like you really hit on something for guys wanting to try 650b but still have a great frame. The numbers look solid too. So that's an XL I take it?
keen said:My agressive riding was tapering a bit so I considered less travel maybe in a 29er platform, I am 6'4" 210lb. Rode a 29er but It was slower and less agile than the 26er. I wanted my RFX to have bigger wheels and less travel. 650b's were a good wheel size compromise. The RFX took well to the shorter rear shock / fork combo. Geometry wise HA is 68* , BB height is 13.5" - perfect for trail riding.
A 08 sultan with 5 spot CS, 5.5 rockers and a 120mm F29. Blunt rims laced to hope pro II hubs. Schwable RR 2.25 in back and a 2.35 nev up front. .Spongebob said:Sure does seem to be the best of both worlds between the 26 and 29er...........
jrm said:A 08 sultan with 5 spot CS, 5.5 rockers and a 120mm F29. Blunt rims laced to hope pro II hubs. Schwable RR 2.25 in back and a 2.35 nev up front. .
70 to 71??? to cheap to buy a angle finder to find out.starre said:jrm: great job in morphing the sultan, but i 'think' i would rather have the geometry of the RFX - specifically the 68 degree HT. what did yours turn out to be? thanx!
