So I took delivery of my new Anthem X 29er 3. I had been curious about exact weights of some of the parts and hadn't had much luck finding them. So I disassembled the bike all the way down to nothingness and weighed each part down to the shifter cable housing and rotor screws.
But since I went completely nuts and did all of this stuff I figured I'd pass it on. Oh well I needed to tear it down for the SRAM XX stuff to go on.
This is a size Large
Existing
Frameset2765.0
Fork 1768.0
Front Tube187.0
Front Tire707.0
Front Wheel957.0
Rear Tube185.0
Rear Tire702.0
Rear Wheel1200.0
Front Axle72.0
Rear Skewer66.0
Front Brake318.0
Front Rotor153.0
Front Rotor Screws13.0
Rear Brake310.0
Rear Rotor109.0
Rear Rotor Screws14.0
Crankset w/o BB872.0
Bottom Bracket0.0
Chain272.0
Cassette w/ plastic spoke guard388.0
Front Derailleur155.0
Rear Derailleur273.0
Front Shifter143.0
Rear Shifter150.0
Saddle222.0
Seatpost313.0
Bars270.0
Stem173.0
Grips103.0
Housing53.0
Front Reflector31.0
Total12944.0gr or 28.51lbs
All weights are in grams unless otherwise noted, the only oddity you may notice is the bottom bracket is listed as 0gr, that's because it is included in the frame weight because I haven't gotten my special tool to press it out yet
Existing
Frameset2765.0
Fork 1768.0
Front Tube187.0
Front Tire707.0
Front Wheel957.0
Rear Tube185.0
Rear Tire702.0
Rear Wheel1200.0
Front Axle72.0
Rear Skewer66.0
Front Brake318.0
Front Rotor153.0
Rear Brake310.0
Rear Rotor109.0
Bottom Bracket0.0
Chain272.0
Front Shifter143.0
Rear Shifter150.0
Saddle222.0
Seatpost313.0
Bars270.0
Stem173.0
Grips103.0
Housing53.0
Front Reflector31.0
