1 - 5 of 5 Posts
· Registered
Hey guys i need opinions on putting a 120 mm fork on my anthem. Personally i reckon the head angle is too steep at 71 degrees and too twitchy. Im currently running 10mm stack height with a 100mm stem. It has a sid on it now.
I use it for xc racing.
Cheers, fire away
· Come on, dare me!
Kaizer said:
Why not use an angleset to alter the HTA instead of bumping up the travel? A 120 fork will be heavier than a 100mm ones.
Not necessarily. Some 100mm forks are wound down versions of 120mm forks using spacers (the RS Reba being a good example). Most of the time, 100 and 120mm forks weight almost the same...
As for putting a 120mm fork on your Anthem, go for it. One of my friends has an older Anthem, which came with a 80mm fork - he put a 100mm and was very pleased with the result.
· Registered
Discussion Starter · #4 ·
Its not heavier if you going to use a carbon lefty :D.
Yea there has been a bit of rave with 120 forks and the anthem but there are some reviews that are displeasing.
My main concern is that will it remain xc race worthy???
· Come on, dare me!
If you plan on racing, buy a 120mm Reba (or Fox) and put 20mm spacers in it to achieve 100mm travel. You can remove them if needed.
1 - 5 of 5 Posts
