'04 Stinky set up very similar to Coiler
Well, I actually got a little first hand experience on this one. I have a '04 Stinky which is nearly identical to the '05 and '06 Coiler in terms of weight and geometry (its for sale BTW
). I have had it set up for an AM bike the last two years so here are my thoughts:
-On descents, rough trails, drops, and jumps it is a solid feeling bike. It gives you confidence that even if you don't land perfect on a drop or jump, you'll come out OK. It soaks up everything in its path and the Fox Vanilla coil over shock is great. Plus, there is nothing like 8 inch rotors...especially on the front wheel for braking power!
-On climbs, the pro-pedal Fox Vanilla R keeps the bobbing of the suspension in check. There is no hiding 37lbs on a climb...you just have to put it in low and grind away. One note, for some reason Kona likes to put 11-32T cassettes on their bikes, I would get this switched out to an 11-34T before you leave the dealer. That extra two teeth really help on the climbs. I also noticed that the 2007 Coilers have a 24t small ring. Again, I recommend switching to a 22t before leaving the dealer. Also, the front end does tend to wander on the climbs due to the slack headtube and long travel fork. I have a fork that can be reduced to 110mm travel for climbs that greatly helps this, but the fork on the Coiler does not.
-I have rode my Stinky on 25+ mile rides with no problems, you just have to know that with a 37lbs bike, you can't be in too much of a hurry. Having 2.3" tires are great, but also slow the bike down due to the inherited friction with the ground. But to me its a trade off, I don't mind being last on the climbs if I can be first on the descents!
Again, hope this helps
:thumbsup:
