http://www.groundupdesigns.com/NRSLove said:I'm looking for a frame with dropouts like that. How do I contact Ground Up? I googled 'em and couldn't find 'em online.
PM me a mail addy and I will give you the phone # as you will proably get no response from via the website.NRSLove said:I'm looking for a frame with dropouts like that. How do I contact Ground Up? I googled 'em and couldn't find 'em online.
the Paragon drops are a bit different and Rollof makes a drop very similar looking also.aosty said:I think Paragon Machine Works makes those dropouts? Anyone know?
if you're merely looking for a bike with those drops, I have seen the new voodoo's with the same.NRSLove said:I'm looking for a frame with dropouts like that. How do I contact Ground Up? I googled 'em and couldn't find 'em online.
different builder...ground up's are fab'd in colorado springs. there is a fair bit of builders subbing out work and i believe some of the wily fillet brazed frames get sub'd out, hence the similarities.appleSSeed said:I do believe those are paragons
and Wily's are available with the same DO's
www.wilycycles.com
same builder too
Daaaaaaaaaaaaaaaaaaaaamn, that bike is hot!
the hydro cable routes on the downtube...i will get some built pic up later today.jh_on_the_cape said:incredible. be sure to post pics of the complete bike.
is that a cable guide by the water bottle bosses on the downtube? I guess I will see when the whole shebang is built up.
I love the pinstripes.
Until recently Eric Baar of GU was doing the fillet brazing for Wily. I know mine, Appleseed's, and motoman's were torched by him.32x18 said:different builder...ground up's are fab'd in colorado springs. there is a fair bit of builders subbing out work and i believe some of the wily fillet brazed frames get sub'd out, hence the similarities.
you are correct....Eric was doing the fillet brazing for Wily. By different builder I meant not Wily cycles producing frames under the name Ground Up.sslos said:Until recently Eric Baar of GU was doing the fillet brazing for Wily. I know mine, Appleseed's, and motoman's were torched by him.
the los
sorry no....only puts out for me.Sparticus said:May I please sleep with your frame?
