My Phils eBB insert is full of dents, they do not affect the ajustability of the eBB. Every time you tighten the setscrew, they imbed a new mark over the old without any issues.New2SS said:I do have one question though, say that in the future I somehow dent the EBB insert with the set screws and it becomes an issue where I can't easily adjust the EBB, is there a place I can go to buy the EBB metal insert?
check Alfred E. Bike.....those inserts are pretty cheap, <$20 - used on all tandems.New2SS said:My Vulture has the set screw EBB. So far I haven't had any issues with it moving or creaking or anything like that....but then again, I only have about 200 miles on the bike. From what I can gather, as long as you tighten it with the right amount of torque, you won't dent the EBB insert with the set screws.
I've never owned pinch bolt or the expanding Bushnell...so I have no clue about those.
bob said:What are the pros/cons between the three types of EBBs; internal expanding, set screw, and pinch bolt? Are one of these the same as a bushnell type?
For the record, I believe any of these may or may not creak so let's not go there.![]()
Cool...that puts my mind at ease.itsdoable said:My Phils eBB insert is full of dents, they do not affect the ajustability of the eBB. Every time you tighten the setscrew, they imbed a new mark over the old without any issues.
Re-creaking - my pinch style BB shell has been the most prone to creaking, which isn't much. Most of my creaks came from the crank interface anyways. eBB creaks have more to do with the BB shell, which is easily distorted during welding. Slight irregularities on the inside of the BB shell gives hot spots for the insert to rock and creak on. Oddly enough, my pinch-bolt BB shell had the largest irregularities.
Thanks JMW, I appreciate the info on that.jmw said:check Alfred E. Bike.....those inserts are pretty cheap, <$20 - used on all tandems.
I replaced my set screw type w/ a Bushnell from AEBike....actually creaks less and keeps the chain tension setting longer (w/o twisting) than the previous set screw one.
I've only greased the Phils setscrew eBB once, when I changed the BB (may as well grease it when you have it apart, eh!). I think among the 3 eBBs, maybe once ever 1~2 years. Use a thick or tenacious grease, something that likes to stay put. I've used antiseize on them, but I don't think that's necessary. Currently using a white lithium based snowmobile grease (because I had a tube sitting in the garage...)New2SS said:How often do you remove the shell to regrease? Also, what is the best lubrication to use on a shell if I ever need to do that? Just plain grease?
Interesting, the Bushnell is the easiest to adjust on the trail IMHO - but why are you adjusting an eBB on the trail anyways? My old park mutitool reaches the bolt, backs it out, and the same multitool in the pin hole allows me to adjust the eBB by turning the cranks agains the tool. Technically, you are supose to use a pin spanner on the other eBB types too, but I've not used the pin spanner for that purpose in 5 years...TomL said:Bushnell type are a pain to adjust on the trail. Long 4mm allen key required and pin spanner...
my GT is doing the same thing, only very slightly, you can hardly see it at the moment but im just wondering if its going to get worse, i'd rather an expanding type if i could chooseGrumpyOne said:Ti and Set-Screw EEBs don't play well together. The BB Shell on mine finally got so stretched out, it started slipping.So it's back at the Mfg. getting the shell cut out. It's going to be replaced with a Bushnell set up.
jw
