see the Rockin' on nails Movie
exactly what i was thinking.NRTH SHORE said:id hate to wipe out on that board.your tire my not leak but you'd shure be leaking.
but all the same it is cool.
is it better than stans?NRTH SHORE said:just another stans sealent .
It contains twice the active ingredient as the leadeing brandJBsoxB said:is it better than stans?
can you use it w/ innertubes?joeyi said:It contains twice the active ingredient as the leadeing brand
you'll see that it says the movie was shot using Joe's Super Sealant in regular innertubes.JBsoxB said:can you use it w/ innertubes?
inside the tubes?joeyi said:you'll see that it says the movie was shot using Joe's Super Sealant in regular innertubes.
There are 1000's of mountain bikers riding around with this sealant in their innertubes.
1000's?!joeyi said:you'll see that it says the movie was shot using Joe's Super Sealant in regular innertubes.
into the tube through the valve, like slime. Sealant is excellent for tubeless and pretty good for innertubes, also.JBsoxB said:inside the tubes?
so that means that you would pretty much change tires the same way?
is it heavy?
looks like it works...IronDad said:1000's?!
Hmmm... and you don't have anything to do with this Stan's knock-off do you? I mean... you started threads on three different forums about this stuff![]()
