Bits and pieces
ncj01 said:
can you give a full spec on that build? I'm curious to see how close mine might be to yours.
Full spec on my 293:
Sram items:
-XO rear derailleur
-XO shifters-ti bolts
-5.0 front derailleur with ti bolt
-PC-99 hollow pin chain
-PG-990 cassette
-9.0sl brake levers-ti bolts
-9.0sl hubs with alloy axles
Bontrager items:
-Race stem with ti bolts
-Race Lite handle bar
-Race Lite cranks with alloy chainring and crank bolts
-X Lite seatpost with ti bolt
-Maverick rims
Other items:
-Selle Italia SLR saddle
-Alloy bottle cage bolts
-Crank Bros. Egg Beater S pedals
-Pedros Blackwall grips
-WTB Nanoraptors-kelvar bead
-Salsa tubes
-Avid BB7 Mechanical brakes-Sram tweaked with ti and magesium hardware, thanks Ed.
-DT Comp spokes with alloy nips
-Salsa Lip Locker seatpost clamp
-Velocity cage
-Marzocchi Marathon fork-bone stock and heavy!
-Fox Float R
-Carbon head set spacers
-King headset
-Truvativ Giga Pipe SL bottom bracket
I have other special mods:
-Sybil link has been machined to reduce the weight by 17.42
-Ti bolts used on the three pivot shafts
-Machined Disc tab on the rear, reduced the weight by a measly 8 grams.
I am not a weight weenie, never have been. I smartly spec my bike with ti and alloy hardware where it is needed. I do not use ti bottom bracket spindles or pedal axles. Just use it were you can get away with it. All my ti and alloy hardware is carry over from other bike projects.
I hope this helps,
Chad
