is this a top pull front der? something looks off.
are you sure you are routing the cable properly? View attachment 1264271
I was actually wondering what the point of that thing on top was. So this is basically an alternate way of fitting the outer casing, presumably for when you're not running your cables through the inside of the frame?^ it is dual action, can be top or bottom. fits more bikes this way
Yep. If your frame has under the top tube cable routing, it would route down through that opening.I was actually wondering what the point of that thing on top was. So this is basically an alternate way of fitting the outer casing, presumably for when you're not running your cables through the inside of the frame?
