1 - 8 of 8 Posts
I have a racing oriented xc hardtail bike. I had a 100mm 6 degree stem and I wanted to improve coming down steep and technical terrain (the bike is ace going up) and maybe give the bike a more fun feel. I'm no expert but this is the impression I have aquired concerning stem changes i.e long stems climb well, short stems come down well etc.
So my first step (out of a series of two or three changes I was planning to make) was to change the stem. Due to a mistake I ended up with a 70mm (had asked for 80mm) 15 degree stem. This is considerably different to what I had so I was kinda expecting a big difference whilst riding.
However although there is a very noticable difference going up (bike alot more 'twitchy' and responsive - which is both good and bad) I can't really say I noticed much of a difference coming down. If anything it's maybe worse as chosing a line and just flowing through stuff isn't the same anymore due to the (over?) responsiveness...
Is this too little of a change to make any difference in the freeing up funky feel I was looking for or am I just weird? Cheers:thumbsup:
100/6 to 70/15 is a huge change and I have experienced big changes when making a 10 to 20mm change in length. Ride it for a while and see how you like it.
I went from a shorter stem to longer stem, and did not notice a larger difference going downhill.
I did notice a huge difference going downhill when I changed my fork to a TALUS, and increased the travel on downhills, (just dialed it back for uphills).
I think this is due to a slacker head tube angle, and the bike sitting flatter cause the front is higher.
Premium Member
I would have kept the same stem length and either just raised it (same stem with spacers) or a stem with more rise. Both will decrease the effective reach with the latter decreasing it more.
The higher bar will let you sit a bit more upright and shift your weight back a bit while keeping it easy to more forward for the climbs.
Discussion Starter · #8 ·
Bird said:
If you have a long grade that takes an hour to climb and 15 mins to descent why cater to the descent?
Good question. The answer is 'cause the descent is difficult.
1 - 8 of 8 Posts
