1 - 16 of 16 Posts
Then you'll basically get the good old Helius FR, that was exactly using the same Tubeset as the Helius AFR with the Fat chainstays plus a stronger downtube. This results in maybe 300 Gramms more weight.
If you do a lot of high drops and park action this might be the way to go. But I had the FR last year and switched to tha AM since the FR was way overbuilt for me.
It will be a tank of an AM for sure!
I think you'd be as well just getting an afr. I've got all 3 here. Am, fr and afr. You'd be surprised how similar they all are. One of the things I really like about the afr is the offset seat tube. The riding position is in the right place but put the seat down and it moves forward and well out of the way.
The afr is on 180mm forks and the other 2 are on 170mm. Ha's are all identical(measured scientifically by lining them in front of each other and eyeballing the fork legs:D). Fr and am have the same bb height(I could have sworn the fr's was higher). The afr's is @ 5mm lower. Seat tube on the fr is slacker than the am so needs the saddle a bit further forward for climbing.
Am weighs 35lb, fr 34 and afr 36
All of the above are available for sale as well:thumbsup:
Discussion Starter · #7 ·
AM will be more suitable for my riding... I was just wondering about the benefits of having a AFR rear!?
Premium Member
It is great for climbing.
The AFR rear allows my adult sized wheels to get more travel.
Dipper,it is an AFR rear built with AM tubing.
Me love it though, great bike. You will all mature to a 29er at some stage
Sent from my HTC Sensation Z710a using Tapatalk
Premium Member
Whafe. Not meaning to be pedantic but what's 'afr' about the rear? Looks standard am to me(albeit in 29er form). The front however is very obviously afr in style.
No, good call, pedantic is all good. I was meaning the area of above the cranks, or the front der tower area... This enable the rear stays to be longer, but a slacker seat tube. I feel this is something that really gives the AM29er an advantage in all things 29ers... Shorter chainstays and more travel = whole lotta great riding....
I was just wondering what an AFR rear could bring to the AM frame since there quite some people using it.
Well tbh not much, the longer chainstays means you can have more travel/clearance before your tire hits the seattube. Whafes is the only am that I know uses it, though that does not mean that they do not exist. He only uses it to gain more clearance to run a funny size wheel
Well tbh not much, the longer chainstays means you can have more travel/clearance before your tire hits the seattube. Whafes is the only am that I know uses it, though that does not mean that they do not exist. He only uses it to gain more clearance to run a funny size wheel.
What is more common is running an afr down tube on an am which means you can run longer forks
ah i see whafe! just crossed wires then.
hmpoliveira
as per ian, i dont know of anyone(on here anyway!) running the setup whafe has and again he only needs it to run big travel with 29" wheels.
do you mean the offset ST of the AFR or do you mean an AFR rear as in the beefier chainstays from?
1 - 16 of 16 Posts
