1 - 20 of 99 Posts
Rider, Builder, Dreamer
hmmmm......
Enduro (get it custom painted red and white) with a red Lyrik Coil up front, Fox DHX air shock, X9 Drive train, BB7s (they're just too darn easy), Thomson seatpost, some red saddle or another, red loc-on grips. White Outlaws w/ black hubs, Panaracer Fire DH (2.3's). White stem at 100 or 110 mm and a 26-inch low-rise bar (also white). Short stem and 29-inch 2.5 inch riser bar for the shuttle days.
Here's mine, items in parentheses will be completed before mud season 2010 is over.
Frame: 2008 Titus Motolite
Color: Mango
Rear Shock: Fox RP23 (to be Pushed with HV Can)
Fork: 2009 Fox TALAS RLC 100-140 w/ 15QR (also to be Pushed)
Brakes: Avid Elixir CR 185mm front/ 160mm rear
Headset: CK Mango
Stem: Thomson Elite 90mm 0 deg
Bar: Salsa Pro Moto Carbon XC Low Rise, cut to 650
Shifters: X9 Triggers
Brake Levers: Avid Elixir CR Carbon
Grips: ODI Lockons
Crankset: Raceface Deus XC, 22/34/Bash
BB: CK Mango
Cassette: SRAM PG990
Chain: SRAM PC991
Front mech: XTR
Rear mech: XO Med cage
Seatpost: Thomson Elite 27.2x330mm (will be AMP all mountain post soon)
Saddle: Selle Italia Yutaak
Rear Hub: CK Mango with Funbolts
Front Hub: CK Mango ISO 15 LD
Rims: Mavic XM 819 Disk Only Tubeless
Spokes: Wheelsmith DB15
Tires: IRC Serac XC 2.1 Tubeless (next season UST Kenda Nevegal 2.1 Rear/2.35 Front)
Pedals: CB Candy SL
Seatpost clamp: Salsa fliplock (found a Mango one on e-bay, maybe switch!)
Cables: Gore
Weight: just under 28 lbs
David B.
Mi nombre es Austin
Niner W.F.O. sand blasted then anodized matte black, 135mm spacing w/maxle
Hammersmit,
12-36t cassette 9spd X-0 shifters silver anodized,
Fox 36 fork with arch cut to fit a 29er,
DHX air shock.
Thomson x4 elite 70mm 0deg rise,
edge composite wheels (29er of course)
nevegals front and back
simple pleasures gnar-bar
crank-bros joplin 4 remote seat-post
seat WTB pure-somethin or other
avid code-5 front and back
G3 CS 185 front 160mm rear
Pro-taper pillow top atv grips grey
Speedplay drillium pedals
power cordz cable system
KMC chain
5.10 Impact 2 low
Santa Cruz chameleon raw aluminum finish
fox F120 29er
SLX compact crank-set (I just love this piece)
XX rear derailer + cassette
power cordz system
X-0 shifters in black
Easton haven wheel on back
Crank-Bros cobalt 29 wheel on front
Code 5 front brake
elixer cr- back brake
Thomson elite x4 stem 90mm 0deg rise
thomson masterpiece post
WTB pure somethin seat
nevegal tires f & r (these things hook up great where I am)
KMC chain
Gnar bar
Crank-Bros mallet 1 pedals w pear-Izumi X-alp enduro shoe
That's it: one nimble XC/Trai 69erl and one All-mountain/Park bike 29er
Seriously with this done up I never looked at another FS again. Having heavy AM and lighter "XC" kit with the components lying around lets me reconfigure this kick @zz bike into 3 - 4 running configs from 30.5lb to ~37lb depending on the trail of the day...
Long travel hardtail is of course another story.... a Blue Pig is on its way as I speak :)
Frame: Titus El Guapo 09 (Med)
Shock: (1) RP23 / (2) DHX coil (ti spring is on wishlist now...)
Fork: (1) TALAS 36 / (2) VAN 36
Headset: Canecreek Double XCII flush 2010
Grips: (1) Some adjustable length lock on grips with DIY cushioning that lets me run super long length of grips :) (2) ODI Rogue
Stem: (1) Titec El Norte 50mm / (2) Straitline SSC 35mm / (3) Brand-X 50mm / (4) Thomson Elite 90mm
Bars: (1) Funn Fat Boy 710mm Lo Rise /(2) Nukeproof 760mm Lo Rise / (3) Amoebi Ti 685mm 2" rise / (4) Steel Torsion SS Bar 690mm (for the "xc" config days)
DriveTrain: Full XT with DCL with E-13 DRS chain guide
Seat Post: (1) KS i900 / (2) 4" drop Gravity Dropper / (3) Thomson Elite
Saddles: too many to list
Pedals: (1) Tioga Surefoot MX Pro / (2) Wellgo WAM D10 / (3) X-pedo Ti
Wheels: (1) Spank Rims laced to CK rear with upgraded heavy duty axle kit, Hope II front / (2) WTB Laser Trail laced to Goldtec rear and Hope II front
Tires: Again too many to list but generally all are >2.3. Favorites- Conti Rubber Queens 2.4, Schwalbe Fat Albert, WTB Prowler XT.
....The Ragley Blue Pig is just gonna pinch whatever not in use in above list when its here next week.
A rear White Ind ENO with 72 eng 18t cog again laced to WTB Laser Trails & a Stylo 180mm crank will take up the duty on the Pig as SS long travel AM HT
2nd set of XT drivetrain will take the place on geared days.
Brakes: again XTs
Ok maybe I just add a PIKE Coil U Turn on my wish list... and some nice canecreek headset. That should complete my 1+1 = 5 bikes project.......... finally
Frame: Team colors Yeti 575 w/rp23 witht the large volume chamber and a DHX 5.0 w ti spring
Fork: Rock shox Lyrik 110-160 mm u turn spring/ revel
Wheels: XTR hubs, Stans olympic rims
Brakes: XTR
Drive train: XT crankset, XTR front and Shadow rear
Stem; thompson silver
Seat Post: Thompson elite silver
Saddle: WTB Rocket V SLT Silver
Tires: WTB Weirwolf 2.3 rear, 2.5 front
This is what I bought
The big ring is gone in favour of e13 DRS, and now has a Thomson X4 stem. Next year the wheels will be built up with CK hubs, and a ti spring for the RC4. Then it's done.
Love it. It's doing AM duties right now, when the Whistler BP opens again it'll see some freeride action.
Blind biker
I just bought mine for over 1/2 off
* Frame Size & Color: small canondale rize 4 in blue, FOX Float RP2
* Fork: FOX Float RL, 140 mm
* Brakes: Hayes Stroker Ryde
* Cranks:SRAM GXP 1
* Front Derailleur: Shimano deore
* Rear Derailleur: Shimano XT
* Pedals:Shimano 520
* Stem:Cannondale XC3 1 1/8", 31.8 mm
* Handlebar: FSA XC-281AOS, 25 mm rise
* Seatpost: Cannondale Alloy
* Saddle:Fi'zi:k Nisene w/MG rails
* Bottom Bracket:
* Cassette: Shimano HG50, 11-34
* Headset:Cannondale Orbit Z 1.5
* Grips:stock
* Front Tire:Kenda small block eight
* Front Rim:WTB Speed Disc XC
* Front Hub/Skewer:Shimano M525
* Rear Tire:Kenda small block eight
* Rear Rim:WTB Speed Disc XC
* Rear Hub/Skewer Shimano M525
* Weight:28.5 with GPS
Price?
I bought my dream bike used so price wasn't much of an issue. I'm too much of a wimp to really need this much bike and my 5 Spot that I've had since 03 climbs better and can handle 95% of what I'll do so I shouldn't have bought this but I dig it so much I just dropped the money. I ride it usually once a week so I'm getting my money's worth.
Fo' Bidniz in da haus
just bought mine and it arrives Wednesday...after having 1 million and three bikes over the past few years, and how I have come to define "AM" FOR ME, based not necessarily on one of the thousand ways the bike mags and/or bike shops and/or bike manufacturers define AM (though I am sure some of their definitions match up with mine), a sub 30 lb somewhat slack hardtail with robust parts is the definite ticket.
Will be a bit slower in some sections than on my FS trailbike, faster on other sections, but overall, prefer the HT, to include the fun factor FOR ME over a FS bike, any FS bike for that matter (would not have said that a few years ago). On the other hand, I also have the best FS trailbike, AM bike, whatever you wanna call it that I have ever owned/ridden and am keeping it for sure so it's really a moot point fortunately for me to worry about a single dream bike.
Santa Cruz Nomad. Best AM bike money can buy. Here's a video that is the definition of "all mountain" if you ask me.
My build: 36 float, i9 classic hubs, stans flow rims, Atlas cranks, Hope 50mm stem, gravity light bars, twenty6 pedals, x9 shifting
1 - 20 of 99 Posts
