I'm 5'11 with a 34 inseam, shortish torso and longish arms.
I'm looking for a new AM/Enduro frame in large (150+ mm travel) and there are a few finalists. I have certain reach numbers in mind but I'm getting preoccupied with seatpost angles. Because I know with a long inseam, the seatpost will be extended further, which will put me further out over the rear axle. While my current bike's reach is relatively short and comfy, the seattube angle is 72deg which is slack...and I can feel it on climbs.
All that being said, I feel like I should be focusing on frames with a 75-76 deg seattube angle and not worry about reach so much because I'll be able to play with stem lengths.
I was looking at the Hightower LT as it looks great across the board but the seatpost angle is slack, especially with a 160mm fork. It would closer to 73deg. Then there's the Spec Enduro 29 with a 76 deg post angle with a 160mm fork. There are others, but these two were just two options I was considering.
Thoughts?
Thoughts?
