Air can enter through the shaft seal or a leaking bladder. I have one and am waiting for mine to crap out. Its supposed to be air free. When mine goes bad, back to the ssv damper fork I go...
Did this reduce the travel of your fork?Jayem said:Mine had sucked in air during the first few months for some reason.... the bladder was so expanded that it was "pinching" the stanchions at about half compression.
How much oil do you have on the TST side? Too much oil there limits travel as well.BigLarry said:Did this reduce the travel of your fork?
When I had my AM1 serviced a few months ago, the ETA stopped holding down right. There was a thread with a big discussion about how much oil was needed in the left TAS side to make it work right, with the final answer being around 130-140 ml (in spite of Marz's web site saying 175+). More than that and the fork wouldn't get full travel, and less than that and the ETA wouldn't hold. But even now, I don't seem to get the travel the whole way. With all my big weight jumping very hard on the fork in the DS setting, I can only go down 110 mm out of 140 travel. That's all my tie wrap shows on the trail too. I seem to remember going down most all the way when it was new. The fork doesn't seem to be reacting quite as well either, but I'm not an expert enough to know really.
I'm now wondering if something happened to the TST cartridge side, which was also serviced at the same time. I do get some sort of subtle rattle or clunking out of the front fork on occasions. Since servicing, I've had to reduce the air pressure in the TST from 55 to 45 psi and it still seems stiff. I need to use the soft DS setting all the time now. But I figured my loosing 40 lbs (from 270 to 230) may also have had something to do with it.
Do any of these symptoms sound like similar to the TST air trappment you describe?
The right amount, I think?MK_ said:How much oil do you have on the TST side? Too much oil there limits travel as well.
_MK
How do I check? I heard somewhere I needed a special thin wall nut driver to remove the screw under the cap . Is that right? What do I look for, a bladder pressing against the inner wall? Where did you get the service instructions?Jayem said:I'd be able to tell pretty fast by unscrewing the top cap of your fork and looking at the bladder.
TST side requires 40-45cc of oil. The fork comes apart just about as easily as a Z1 with addition of having to remove the two knobs from the bottom. Not sure how to check. Maybe unscrew the ETA side top cap and compress the fork, see if you can get it all the way to the bottom.BigLarry said:The right amount, I think?
My LBS did the repair, and they're Marz experts with close ties to the Marz techs. For example, they told me up front about the fork needing 130 cc of oil in the TAS side. But it took me a couple iterations like me having them setting the fork with the 175 cc spec on Marz web site only to find less than half travel, just like they warned.
However, they weren't familiar with AM1's new TST rework at the time, but one of Marz techs personally trained them at a race booth, as they said that side was a bit tricky.
130mm in the TAS side is a little too low also. I have found that 140ml is optimal. I know you said that the shop folk are "experts" but did they bleed the entire cartridge before adding the fluid back to the TAS side? Too much oil over there will definately limit travel.BigLarry said:The right amount, I think?
They said they indeed removed all oil and cartridges before bleeding. They also will not "add" say 10 ml to get from 130 to 140. They say the only precise way is to dump it all, with cycling to get every drop out, and insert the exact amount from a calibrated syringe-type pump they showed me. (I'll need to get one of those too.) They said it could be a few ml over 130 cc. They initially told me it was 140, but weeks later admitted they'd actually reduced the last working fill closer to 130 ml that they felt confident was correct, but told me it was 140 ml just to satisfy my demand. The ETA held down so I'm happy just the same. I just want to figure out what happened to the last 25+ mm of bottom travel.SSINGA said:130mm in the TAS side is a little too low also. I have found that 140ml is optimal. I know you said that the shop folk are "experts" but did they bleed the entire cartridge before adding the fluid back to the TAS side? Too much oil over there will definately limit travel.
No, I've been using Reed's, the Heckler dealer. Jesse there seems to know Marz forks extremely well. Still, I've been tempted to try Trail Head for a good second opinion, but they've got a 3 to 4 week back log each time I ask.spongstick said:I'm from San Jose Big Larry,and I have the same fork,did you take it to trail head?
While I haven't seen any reports of Marzocchi seals not holding air at low temperatures, the issues in not at all uncommon, particularly with Fox rear shocks. The fact that the fork held air at your house, where it is warm, and lost it on trail, where it was cold, points in the direction of the seals shrinking enough at low temps to let air past. I would contact Marzocchi and get them to send you a new set of seals or get a set from Enduro.dawgboy said:Conditions both days was cold at about 25 degrees F. Muddy/wet/icy on Sat and snow on Sunday. Both were slow rides because of the conditions.
